GSP Sale
GSPBASSESGSPBASSES Frets: 2351
edited April 26 in Parts £ tFB Trader
Alder Body
Roasted maple flame neck
 Rio Rosewood fingerboard
JD 6105 frets
1st fret 22.5mm
12th fret 23.8mm
Total weight 5lb 9oz (body &neck)
Supplied with a full kit of hardware.
This guitar is classed as a B grade and there is a small chip out the back of the headstock.
£300 + £12 P&P.  SOLD
Swamp Ash body
Plain maple neck and fingerboard
JD 6105 frets
1st fret 22.4mm
12th fret 24.5mm
Total weight 4lb 14oz (body & neck)
This guitar is classed as a B grade there is a small crack in the bottom of the body, this has been repaired with glue being injected into the body.
Swamp Ash body
Plain Maple neck
#154 frets (.100” x .050”)
1st 21mm
12th 22.7mm
Total weight 5lb 7oz (body & neck)
£300 + £12 P&P SOLD
LP
Mahogany body and neck, Cream binding on both.
Flame maple cap.
Crown inlays (acrylic)
1st 21.7mm
12th 23.8mm
There is no hardware with the guitar.
£350 + £12 P&P
This is a B grade LP, as you can see there are some marks in the flame Maple cap, also the neck pickup route is slightly oversize although the pickup ring will cover it up as normal. This is one of my slim line LP's, its weight is 5lb 7oz.  I tried a new supplier of fingerboards with crown inlays, and to be honest they're not the best I've ever come across another reason why the guitar is classed as a B grade. I’m sure with a little bit of TLC this will still make an excellent guitar.
The hardware supplied with the TC’s is mainly Wilkinson, there are CTS pots with an orange drop capacitor. The hardware kit contains everything you need to build the guitar. There is no lacquer or colour with the kit. I would recommend Crimson guitars water base colours plus they clear oil finish to complete the guitar.
  • TheMarlinTheMarlin Frets: 8024
    PM'd
  • fastonebazfastonebaz Frets: 4134
    @Lebarque build Yr own LP
  • GSPBASSESGSPBASSES Frets: 2351
    edited April 24 tFB Trader
    Now all the difficult work is done they are quite easy to build, no harder than any other part caster.
