Les Paul 1999 Purchase.. a little help
  • NCoNCo Frets: 163
    edited April 27
    Everytime I had a Gibson LP I replaced the stock 300 pots and saw a massive improvement. Likewise, Every 490/498 pickup set I had ended up being replaced, and I always disliked that set on every guitar I tried.
    Therefore, personally, in this case (and all other caveats), if I were buying this guitar I would already know that the pots and pickups will be replaced on sight.
  • OilCityPickupsOilCityPickups Frets: 10692
     ... but that is totally subjective.
  • guitars4youguitars4you Frets: 14389
    I'd certainly say yes to the pot change first with a new set of 500K pots - Then I'd leave it again and listen to what is on offer and appraise accordingly - Depends on your style of music of course - A die hard metal fan may well favour EMG's, but I'd rather listen and take it in for a couple of weeks first - The pots are a major factor as I want the controls to function effectively from 5-10 as that is where the emotion, soul, is
  • NCoNCo Frets: 163
    Yes, tone is subjective, which is why I said "personally". I just offered a counter to some posts speaking in absolutes, such as this:
    My advice ALWAYS as a pickup manufacturer is live with your existing pickups on any new purchase for long enough to make a proper decision. If you like them great you've saved some money. If not you will have a better idea of where your existing pickups are falling short of your expectations.
    To summarise, in some cases it is a perfectly reasonable approach to buy a guitar knowing you will change pickups and the loom, or just simply replacing it straight away.
  • robgilmorobgilmo Frets: 3600
    For that kind of money I would be enjoying it as it is and not filling myself with notions that the pickups and wires werent good enough, as they say, a good tradesman never blames his tools.  :#
    But then again I couldnt tell the difference in a blind test between a gibbo and any other guitar anyway never mind pickups or wires.
  • timmypixtimmypix Frets: 2420
    For £1500, if you're getting the chance to play it and you like it, I'd snap that up in a heartbeat and worry about the details later.
    If there's anything you don't like and you decide to move it on later, you won't make a loss and may even profit, so it's a no brainer at that price.
    Tim
  • TeleMasterTeleMaster Frets: 10278
    Can you get to play it? I had one from that period - massively heavy and generally not great. Post 2002 models were significantly better.
    90's Les Paul's are great, they can be heavy but they all can. I've had a few and I miss them all.
  • tone1tone1 Frets: 5187
    edited April 27
    My 2000 Les Paul Standard is pretty heavy (coming from a 7lb Strat) but it sounds glorious….and I haven’t tried a lightweight Les Paul to compare.
    edit….when I bought it, I asked how heavy it was? The seller said…..how heavy do you want it to be?  :)
  • sloan1874sloan1874 Frets: 7
    I've had a word with the guy, he's a top bloke with loads of experience with instruments, live music etc, and we're going to sit down and have a play and see how it feels. I've only ever owned Fenders with slim c-shaped necks, so it'll be interesting to see how the thicker type feels. I will report back on what happens!
