These can becomes scaled and stop working.
The easiest way to fix it is to replace the thermostat.
I get plumbers to do it because I don't want to fuck it up, but it can be done by a careful individual.
Football is rubbish.
It works with 2 ceramic plates that slide over each other.
Easiest way to get a matching replacement is to bring the old one to a plumbing supplies shop, as there are a number of variables (depth of the cartridge, length of the shaft for the mixer control to attach to and the number of teeth on the spline)
Trading feedback here
If that doesn’t work, you may need to start replacing stuff.
Turn water off
Unscrew and remove it
Screw in replacement
Turn water on
Other steps as per your mixer.
Something like this or similar for your model.
https://www.screwfix.com/p/bristan-thermostatic-mixer-shower-cartridge/9864j
