Instagram
Any ideas for a more permanent solution? The seller seemed to think a spring of some sort would be needed, but he wasn't much more descriptive other that that!
https://www.fender.com/en-GB/parts/bridges/american-series-stratocaster-tremolo-arm-tension-springs/0994931000.html
Presumably Eric Johnson can tell the difference between different brands of tape.
Try to wrap the tape over the vibrato arm threads so as to form a gentle taper - thicker towards the bend in the arm. This helps the tape to fill the slack in the block threads.*
* This is how PTFE tape achieves its magic.
BUT
… did the 1986 MIJ Stratocaster feature this or Fender's own System 1 vibrato?
https://reverb.com/item/65353032-fender-stratocaster-standard-model-2-w-kahler-tremolo-1987-vintage-white
I'm assuming that bridge is original... it wouldn't be a direct replacement for the System 1 as I think that had wider stud spacing:
This is useful, since it means you can replace the Kahler with a USA Std bridge when the Kahler becomes unserviceable. (Although the string clamp at the other end also needs to be removed and a string tree fitted.)
And you can still buy spares:
https://whammyparts.com/manufacturer/tremolo-and-bridge-systems/make-model/kahler-replacement-parts/25xx-traditional/results,1-0
