It was always on, so the sound was always overdrive, then when it came to solo time the volume was boosted so the amp gave more drive and cut.
Struck me as being neat, but a volume pedal would do the same job. Take up board space, mind.
"The Kickdisk is easily attached to your pedal by carefully removing the factory knob from the shaft and sliding the Kickdisk down in its place."
fnarr fnarr
