And yes, for me a reverb is an always on pedal, even when the amount I use is very little.
Only the V2 stereo pedals can go 100% wet signal. The V1s (identified by the green in the logo) can only go 50/50 wet/dry.
Any of the V2 pedals can be any of the others using the software. Seeing chroma chorus or echelon pedals cheaper than the wet? Same pedal, if you can deal with the graphic not matching what's in there you're golden.
What I did was to get a cheap Echelon then get an ExP Audio Expander Controller (now discontinued I think).
This way you can download & have access to most of the V2 pedals at once.
The Golden does pseudo-analog better than the Immerse, but I miss the super clean giant ambient thing the Neunaber does sooooo well...
It had a slapbacky pre delay you couldn't dial out.
