P90s are single coils but, perhaps, not the sort you desire.
Alegree had a Frigid Haze (Stratocaster) single coil in a humbucker cover listed in his Clearance section.
EMG-H, -HA
Mojo Pickups also has HB-sized P90s, Charlie Christians, gold foils and filtertrons.
https://youtu.be/3k9nS4JtANU?si=FT_BPCsjAc8AiKLH
Yeah - the guitar has splits already. It’s very uninspiring.
I have some, they are really crisp sounding, and I am usually a single coil guy, since forever.
The resistor simply connects between the coil split junction and ground (or hot, if you’re splitting to the other coil) - the value is best determined by trial and error, or it may be better to fit a trimmer. 5K would be a good value that includes all the useful range for most purposes. PRS uses 2.2K for the bridge pickup and 1.1K for the neck.
I would guess the Frigid Haze in a humbucker cover you mentioned would do well for the single coil tones, but I haven't tried it. It really depends on whether you need the humbucker tones too- if you do, the Gemini etc. ones are the way to go. If you don't, I would guess the Frigid Haze (and similar) are.
Or the standard humbucker plus resistor trick for splits... if the humbucker tones are most important.
(I agree with you about P90s- I know they're technically single coils, but they don't really sound Fendery, at least to my ears.)
Agreed, although I had a couple of guitars where I had them fully up to 5k and still would've liked a little more leeway. My feeling is- just to be absolutely safe- 10k on the bridge pickup and 5k on the neck. (5k does give you more fine control, and I'm not sure why those couple of guitars were still a little thin, IIRC they were actually slightly hotter than some other bridge humbuckers which were absolutely fine with quite a bit less than 5k! I don't think I'd accidentally selected the screw coil either, again I think I did that on at least one guitar and it was fine with 5k...)
Order with 4-conductor + shield output cable. This will make it easy to resolve phase issues with your other pickup(s).
