Is there a quiet 7 band EQ pedal?
paulnb57paulnb57 Frets: 3121
edited July 21 in FX
Fancied trying an EQ pedal and have now realised what Ive missed out on for years, seriously if you haven't tried an EQ pedal, do it…only issue is its noisy, as soon as a slider is moved from the flat position there is hiss
Granted its a Behringer and its going into the input of quite a high gain head, I only got the Behringer as its cheap and let me try an EQ out…
Is there a silent or more quiet option out there that wont break the bank?
  • RevolutionsRevolutions Frets: 429
    Yes.
  • paulnb57paulnb57 Frets: 3121
    Yes.
    Is it a secret?
  • matt_seftonmatt_sefton Frets: 861
    paulnb57 said:
    Yes.
    Is it a secret?
    Johnny the shoeshine boy told me it’s a Boss GE7
  • WazmeisterWazmeister Frets: 9770
    New GE7 are silent, as is EQD Tone Job.
  • TTBZTTBZ Frets: 2968
    Danelectro Fish & Chips used to get recommended a lot as a good quiet and cheap EQ, if you can stand the looks and can still find one.
    Thanks Chaps! A Boss will replace the cheaply…
    Police Squad! That takes me back!
  • SporkySporky Frets: 29408
    There was a BYOC one too. Bit of a pig to build,  but worked well. I think I've still got mine somewhere.
  • Flanging_FredFlanging_Fred Frets: 3169
    I use a Source Audio eq now for the presets but I also have the fish n chips and can confirm it’s really quiet (noise wise).  I actually like the sound of the Dano better than the SA, it’s sounds a little warmer to my ears.
  • HeadphonesHeadphones Frets: 1018
    I've a Joyo one that does teh deed well.  I presume it's a clone of something...
  • TJT1979TJT1979 Frets: 200
    How are the newest Boss GE7s in terms of noise? I expected them to make a fancy Waza version by now
  • ICBMICBM Frets: 73540
    The new ones are fine - although I’m still baffled it took them so long. I’m not sure what a Waza version could do better…
    Totally silent
  • guitargeek62guitargeek62 Frets: 4307
    Yep, they’ve been great since the last revision in ~2021? I’m not sure if there’s an accurate way to tell prior to buying/trying though, so the secondhand market for them is still a bit pot-luck unless they have receipts and/or audio demos!
  • koss59koss59 Frets: 870
    In my opinion a waza one should have a switch to permanently have the EQ section turned on or off and the foot switch control just the level.
    That way you could have EQ and boost in one pedal.
    Facebook.com/nashvillesounduk/
    That’s a very neat idea.
