Strap buttons working loose
LebarqueLebarque Frets: 4066
edited July 24 in Guitar
Got a new (to me) guitar and the strap buttons keep working loose.
They're also too short to use grolsch-style rubber washers, which is my preferred method of ensuring the strap stays on.
Any tips?
Ps. I don't like strap locks
  • Philly_QPhilly_Q Frets: 24815
    New strap buttons, bigger/longer screws?
  • FunkfingersFunkfingers Frets: 15093
    edited July 24
    It is quite possible that the previous owner of your guitar had fitted fancy strap buttons only to remove them immediately prior to sale.
    If the screws on the "upgrade" buttons were wider or longer than the stock ones, this would explain the lack of grip for the originals.
    The obvious options are either to use a larger screw or to reduce the diameter of the hole. Gluing in part of a cocktail stick is the traditional solution.
  • stickyfiddlestickyfiddle Frets: 28492
    Change strap buttons. And put a glue-covered matchstick in each hole while you're changing them
  • EricTheWearyEricTheWeary Frets: 16622
    edited July 24
    My only bit of successful DIY - remove the button, put wooden cocktail sticks (non sulphurous end of matchstick if you haven't got cocktail sticks) dipped in wood glue into the hole, trim off and rescrew. Obviously wait for the glue to dry before applying any pressure.
    Edit: replace the screw and button whilst glue is wet but allow to dry before using it as a strap button.
  • ICBMICBM Frets: 74041
    But importantly, put the screw in first while the glue is still wet - *then* leave it to set before using the button. I know that’s probably what you meant, but I wasn’t quite sure :).
    Yes, screw in whilst the glue is wet. It wasn't clear
  • RockerRocker Frets: 5088
    You spent some/a lot of money buying the guitar so buy proper strap retainers to keep it secure on a strap.  They are not expensive and they don’t give you a hangover.
    Nil Satis Nisi Optimum
  • fretfinderfretfinder Frets: 5201
    edited July 25
    I’ve repaired loose strap button screw holes many times, always successfully, and I’ve always let the glue dry in the hole with the cocktail sticks before putting in the screw. I don’t want wet glue seeping out of the hole as the screw goes in (the displacement laws of physics apply here) and then have glue drying on top of my guitar’s nitro finish unseen underneath the strap button. YMMV but I’m going to keep doing what’s always worked for me.
    260+ positive trading feedbacks: http://www.thefretboard.co.uk/discussion/57830/
    Groslch ones are the best available. You can buy them without buying beers if you need to :)
    Every other straplock relies on even more mechanical stuff not failing…
  • JonathangusJonathangus Frets: 4968
    All my guitars get a set of these, plus a Grolsch-style washer if the strap isn't too thick.
    https://www.gluedtomusic.com/products/730/gotoh-ep-b3-large-oversized-strap-buttons-set-of-2-chrome/
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
  • Fishboy7Fishboy7 Frets: 2328
    Strap locks look crap - Those rubber Grolsch washers work fine
