Heat gun is best but take care not to scorch the wood. You'll need to sand afterwards to remove any residue.
I don't mind if I scorch it a bit - as sad as it is, I've always liked the fire damaged look!
It’s really easy, just go slowly and start under the scratch plate so if you mess up it won’t show
https://www.thefretboard.co.uk/discussion/233558/stripping-a-baja-2022-version/p1
I have managed to leave the majority of the sanding sealer coat on the rear and sides of the body.
What heat gun did you use?
