I painted the plaque and screw heads orange, then glued the plaque in to place using superglue.
Third & final coat of clear varnish went on. Dried in approximately 0.03 of a second in the heat.
that.. but.. decided to add some flair to the velcro situation..
of dry varnish and made sure they all lined up in the frames. One didnt so I re-drilled it.
The original plan for the demo board I put together for the show was actually to put a white LED behind the logo plate on the side, I just kinda ran out of time to get it done properly. I think I definitely like your idea more, though
Incidentally, if you want cleaner lines on top, maybe try using Dual Lock instead of Velcro? Only a minor suggestion, though, it looks absolutely ace as it is.
https://www.amazon.co.uk/gp/aw/d/B0B7NH2ZB5?psc=1&ref=ppx_pop_mob_b_asin_title
3 metre, £3.99 currently. The AAA battery box is a bit
of an eyesore but I covered the topside of it with velcro so it looks less offensive haha.
A quick study of the pics will show only half the screws are in.
This is because at 600mm the slats are too short to make a long enough board to mount my loved side jack pedals. That's YOU Chase Bliss, darn your lovely sounds and versatility...
As you can see this results in a Tonex rotated 90° and that really triggers my OCD.
New wood will be purchased tomorrow.
On a more positive note a Thomman ISO10-AC Pro fits just under the board. Cheap, lots of power and three switchable outs with seven 9V. Also a mains lead, not a wall wart.
I still double the outs to current critical devices like the Tonex and my GT100core.
When I say 'just fits' I mean the bottom edge of the PSU is level with the bottom of the board.
Feet will be purchased today.
Cable management is a mess and apart from putting the clips in will remain so as the board will change depending on the occasion. This is the range of stuff that regularly gets swapped in depending on my mood on any given day.
There are more in the cupboard.
I also use a small second board for control when actually (very occasionally) gigging.
An FS-6 and a couple of FS-7s for when I have the Boss GTK Core on the board or want to easily change Tonex presets, plus one for the looper as I hate the double tap to stop feature on the RC-5. The faves and OBNE Expression ramper really help get the most from the Mood or even the Cloudburst and Brig.
I'll make a tidy linking snake when I work out what I want most of the time.
Thanks again for doing this. It prompted me to get off my arse and change things. Also prompted me to sell stuff I haven't used in a while.
Please excuse the rug. Borrowed from a 1980s readers' wives photoshoot...
Hmm. Can you still buy that copper tape with adhesive on one side to make the contacts? I must check ....
An small engine and control module would be attached (not shown), somehow, which will power the wheel.
Obviously this is an early idea, a prototype as such but the only downside (apart from cables which I'll get to in a minute) is that the wheel will not be controllable so its kind of sucky if you need a certain pedal at a certain time. It could sometimes enter reverse also.
The wheel will still spin, otherwise the whole thing is pointless tbh, although I can't actually see the point in the wheel spinning if you're inside it because it kind of defeats the reason it was invented in the first place.
Hmm. Wonder if Slim wants to endorse it?
