Best Tube Screamer type pedal?
13»
  • Dave_McDave_Mc Frets: 2382
    Well sure, I mean it's still an od (actually, IIRC with the gain on zero it's a genuine clean boost as it has a dual-gang (think that's the term) pot which removes the clippers from the circuit).
    But yeah it's also not TS-derived. Again IIRC doesn't it have (germanium) clippers to ground?
  • ICBMICBM Frets: 72734
    edited September 2013
    Brize said:
    Different circuitry but similar application, no?
    Similar application, yes - but it's nothing like a TS in almost any part of the circuit.
    Yes, which makes it a "distortion", and hence proves exactly that whether it's an overdrive or a distortion is dependent on the application and not the circuitry really! (Even though I would say that generally 'hard' clipping is distortion and 'soft' feedback-loop clipping is overdrive.)
    The diodes are not removed from the circuit at low gain settings, it's just that the gain can be reduced to below the point that they operate.
    ICBM said:
    (a) Yes, which makes it a "distortion", and hence proves exactly that whether it's an overdrive or a distortion is dependent on the application and not the circuitry really! (Even though I would say that generally 'hard' clipping is distortion and 'soft' feedback-loop clipping is overdrive.)
    (b) The diodes are not removed from the circuit at low gain settings, it's just that the gain can be reduced to below the point that they operate.
    (a) agreed
    Don't the germanium clippers clip a little more softly than silicon? If so, I suppose that might go some way to explaining why they can claim it's an overdrive...
    (b) My mistake, I got confused with the dual-ganged thing >:D<
    So what's the purpose of the dual-ganged pot- just to reduce gain in two parts of the circuit?
