Old style Marshall Guvnor...
Drew_TNBDDrew_TNBD Frets: 22445
Does anyone have a baseplate for one of these? I've got this:
But it needs a bit of TLC...
  • I think that will share the same base plate as the shred master and drivemaster etc?
    You can get drive masters for £20ish on ebay if you are lucky.
  • mike_lmike_l Frets: 5700
    The Shredmaster is a different case altogether. By eye the Guvnor is about 10mm shorter.
  • Paul_CPaul_C Frets: 7922
    cardboard and gaffa tape?
  • ICBMICBM Frets: 73031
    I'd consider re-housing the whole thing in a standard box with upgraded parts. The switch and jacks are crap and and the knob placement isn't ideal
    Unfortunately the Drivemaster isn't the same shape so the casing won't fit.
  • ahhh dont listen to me then :-)
    A rehouse sounds like the best option then
  • stonevibestonevibe Frets: 7203
    I'd re-house it and re-do the jacks and switch. They are the two weak links on these pedals as already mentioned.
    My old one is great, but these two issues stop me from gigging it, as I think I may kill it.
    Guitar Bomb & Nembrini Audio Summer Giveaway
    Ah I was going to probably flog it, but if it aint worth much and I can't get a replacement casing for it, don't think I can be arsed to rehouse it!
    Re-house it and it would be a Prince Of Tone clone...
