My personal opinion and that based on teaching is that the CAGED system gets people up and running faster for obvious reasons - 2 less shapes and limited area to cover. Also plenty of guitar icon have survived (either knowingly or not) on using the CAGED system or even less boxed positions.
The main downside to the CAGED system is you can literally end up boxed in and dependent on singular positions. This is easily breakable if you deliberately set about doing so and focus on transition between shapes.
We were forced to learn both variants and in an perfect world (baring in mind we were practicing at least 8 hours a day) then that would be the 'ideal' solution as I see it. Unfortunately for most people time is a limit and the more easily recognisable shapes and more instantly accessible shape of the CAGED system make it the preferable choice for most.
Another advantage of understanding the CAGED system is that as you progress is that in non-diatonic chordal progressions it is clearly far easier to see and highlight chord shapes.
3NPS is (IMO) a better tool, once you've got CAGED under your belt.
CAGED is great for seeing how a chord/scale are interlinked, and as RHC said, for a lot of players is enough to cover all their playing needs.
3NPS links the different shapes together and covers the missed bits between them.
if any of that makes sense.......
As someone said learn them both... learn as many scale patterns as you need until you've got all the finger placements in your hands and know all the notes under your fingers... by then the individual patterns will be a dim memory.
What I would say is that CAGED links up to chords more, by virtue of spanning across the neck where much of the more spanning 3NPS patterns confuse that by removing the one-to-one mapping.
Basically, before I try to get too clever with different keys, I want to get Em under my belt, but would like to expand with this 3nps idea.
I feel like I'm missing something?
Maybe the pentatonic having less notes would involve larger stretches.
imo. Start with Gmajor 3rd fret bottom E string and play the Gmajor scale 3nps.
ie 3 5 7
357
457
457
578
578
This scale takes you through the e and d shape of the caged .
Yes, whatever you're looking at is wrong.
CAGED system Em (Aeolian) at 12th fret =
12-14-15
12-13-15
11-12-14
12-14 (only two notes)
12-14-15
12-14-15
Whereas 3NPS would be =
14-15-17
13-15-17
12-14-16
12-14-16
12-14-15
12-14-15
If you were to just cover one octave on the lowers strings the they appear the same pattern but as you can see beyond that they are different.
