Tremolo in the FX Loop
shaunmshaunm Frets: 1641
Do you guys do this? I've been experimenting and quite like the sound. Do people usually put the tremolo before the delay if you do put it in the loop?
    edited December 2014
    Do you want to run the delay and the tremolo at the same time? It'll give a pretty different result swaping the order, certainly one of those cases of "no right or wrong way of doing it".
  • shaunmshaunm Frets: 1641
    Yeah I will be running them at the same time. I've never run the trem in the loop on any other boards I've had I've always had it running after the drive pedals. I have been using the trem as a bit of a texture thing for solo's and not in a really "tremolo" sort of way.
  • ICBMICBM Frets: 72929
    I usually put both tremolo and delay in the loop - delay first.
  • RaymondLinRaymondLin Frets: 12026
    I have my warped vinyl (for a bit of trem sound) before delay.
