Damn, damn, damn.
I only recently got the Blackstar 260TVP with a cool cover to go and the footswitch... and it sounds amaaaaazing!!
BUT!! It's just too heavy and bulky for me! I had to take it to practice today and just about did my back in! I even bought a little trolley for it but it didn't help all that much.
So I'm probably going to sell it in order to buy a light single-channel amp with great clean, and just run my pedals through that. I have a Riot pedal for distortion and it still sounds pretty damn good.
Any recommendations? Originally I was looking at the Matrix VB800 & NL12 cab but combined that is a very costly option. I really wish I hadn't sold my Roland Cube 40X now... That weighed something like 10kg and was about right, but the BLackstar is something like 26kg which is too heavy for me. Honestly, I just can't handle it.
As a side note... when I played through the clean channel my boost pedal worked a treat. However the boost pedal did NOT boost the volume as soon as I went into an overdrive channel. Strange?
Or maybe something more exotic. What's the budget? You could probably ask mjw or another UK builder to build you a 40ish watt clean voiced valve amp in a head shell and go from there.
Not a big fan of the riot, but I'd imagine it would get a good crunchy sound from a fender style amp quite easily.
But the hot rod deluxe is pretty much the go-to as a clean pedal platform. No frills, just good tone.
You won't need to buy a new footswitch either...
No, a boost pedal will not boost volume when going into an overdriven amp, just increase distortion. It might increase volume a touch if the amp goes from not very dirty to very dirty, but not much.
My YouTube Channel
My YouTube Channel
My YouTube Channel
Wouldn't it be easier to just get a good amp and use a trolley or fit wheels (unless you have a back problem or several flights of stairs to deal with)
Maybe a head and cab is the answer? My evh50 and 2x12 are an easy one in each hand trip to the car - a 1x12 would be even easier but I've been happy with a single speaker on stage.
My YouTube Channel
The blues cube looks like a great grab and go, I really want to try one.
If money is an issue, remember you'll be selling the blackstar anyway - you will lose some money, but not loads
My YouTube Channel
My YouTube Channel
My YouTube Channel
Man up !
My YouTube Channel
