Effect order in an FX Loop (adding an EQ)
not_the_djnot_the_dj Frets: 7306
edited December 2014 in FX
I'm currently running some pedals in my loop, but looking to add an EQ pedal. So where would that be best...it'll be an on all the time pedal.
Current order: MXR Anologue Chorus > TC Spark Booster > T-Rex Delay > TC HoF Mini.
Would it make much difference if the EQ pedal was at the start (my hunch for that right answer) or at the end (best solution layout wise).
  • randomhandclapsrandomhandclaps Frets: 20521
    It would give you the most flexibility and final ability to tailor your tone at the end.  How much (compared to at the start) depends on how much the other pedals are effecting your tone.
  • ICBMICBM Frets: 72928
    I would put it at the end.
  • VoxmanVoxman Frets: 4787
    +1
    Paralell or series loop?
    Series. Blackstar HT-50
