How much is it going for? £200 - £250 for the head is around the going rate.
He bought the 2nd amp to drive a separate cab so now uses both at the same time.
Then they had their "Crashdown" phase.
I was under the impression that the latest ones were better?
I forgot to say, it was the speaker that had blown. We discovered that the following day.
Its really helpful to have your insight into these units guys. TBH, I'm not going to push it hard at all, a colleague of mine doesn't need it anymore and I'd like a bass amp, I want to make a sensible offer.
If it breaks I will be the one fixing it, so the time involved in the labour element isn't a concern provided that it is possible to obtain the parts. It sounds to me, from what you have said that they are made from standard obtainable bits.
I've even been know to rewind a transformer or two before now, not that I particularly want to do that again!
I will also take a look at the Behringer too. Thanks
