Uni vibe placement
mark_jwedgemark_jwedge Frets: 318
So I have got a madbean harbinger one uni vibe, wired true bypass so is currently first in the chain before my fuzz face and my other drives. I was just wondering what the general consensus was on where most people would place it, before/after fuzz, before/after drives, in the loop even?
  • GassageGassage Frets: 30931
    Univibe is the real 'use your ears' placement pedal....most are pretty defined. These are not. I'd always put after dirt and before delay
  • I go with before dirt.
  • fretmeisterfretmeister Frets: 24470
    Before dirt
  • FazerFazer Frets: 467
    i tend to go with phasers after dirt, but univibe before
  • RMJRMJ Frets: 1274
    Pre dirt for best toanz
  • breadfanbreadfan Frets: 379
    My chain goes:
    Wah, vibe, fuzz, phase, od/dist, delay.
  • TheCountTheCount Frets: 274
    Before dirt or shit gets too noisy- wooooooooooooooooosh
  • If I had a use for such a thing I would put it on the floor
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • Before drives me likey
    Seemed like a good idea.....
  • After fuzz (like Hendrix apparently) but before the overdrives for me.
  • ^this
  • john_rjohn_r Frets: 130
    If you want to sound like Jimi put the vibe after everything unless you are using a delay or reverb, in which case put that last. The phasing effect will be far more pronounced and your original tone will be altered a fair bit, not to everyone's taste. Put the vibe first it will sound like more like the Robin Trower type of tone, both sound good:)
  • mike_lmike_l Frets: 5700
    You have "shit" in your signal chain?
    No wonder it sounds farty.....
