Floyd Rose Trems and the 12" radius
Handsome_ChrisHandsome_Chris Frets: 4780
edited May 2015 in Guitar
If you have a guitar neck with a 12" to 16" compound radius neck, how does having a FR trem with, I believe, a 12" radius work?
  • Andyjr1515Andyjr1515 Frets: 3129
    Interesting question..... In fact same question for any radiused bridge
  • Handsome_ChrisHandsome_Chris Frets: 4780
    Anybody?
    Someone must know? I mean I thought that  the radius would get larger at the bridge.
  • MattFGBIMattFGBI Frets: 1602
    Shim the outer saddles if it becomes an issue. I've never found it to be a problem to be honest.
    This is not an official response.
    contactemea@fender.com
  • WezVWezV Frets: 17501
    The saddle can be shimmed if needed.
    The bridge radius does need to match the fretboard radius, although its worth confirming the actual radii used on the fretboard. If its 12" at the nut and 16" at the 24th fret it will be even flatter by the time it gets to the bridge.
  • chrishill901chrishill901 Frets: 519
    Never really gave it any thought. My Jackson SDX has a 12-16" compound and a Floyd and there are no playability issues whatsoever. In fact quite the opposite, it plays beautifully
    Check out my band Coral Snake if you like original hard rock!
  • mike_lmike_l Frets: 5700
    Same with my Charvel. Never had a problem.
