new pots, switches etc
1nten5e1nten5e Frets: 245
I have a 2 humbucker tele that a mate needs work doing on, it needsnew pots, 3 position switch and jack etc....where's the recommended places?
  • rlwrlw Frets: 4791
    depends on where you is innit.
  • axisusaxisus Frets: 28355
    I'd use the routs that are already there. Makes for a much neater job.
  • 1nten5e1nten5e Frets: 245
    I'm on the internet
    cheers
    well thanks for the help :p
    You could check ou this thread quite easily as it's at the top of the list
    http://www.thefretboard.co.uk/discussion/18/recommended-luthiers-techs#latest
    or are you asking where to buy parts?
    yeah sorry, just need to buy the parts
  • Hertz32Hertz32 Frets: 2248
    Allparts, thomann, stringsdirect
    'Awibble'
  • chrisj1602chrisj1602 Frets: 4079
    Axesrus.
  • ChalkyChalky Frets: 6811
    Surprised we don't see more recommendations for pots and suppliers. Is there no difference in pot quality? Will anything do?
  • John_PJohn_P Frets: 2756
    Axesrus.
    +1   cheap and quick.
  • ICBMICBM Frets: 73235
    No, definitely not. There are big differences in quality. Generally you want Alpha for guitars with 'far east size' 8mm bore holes, and CTS or Bourns for 'US' 3/8" bore holes. CTS are the traditional 'best', but their quality varies widely too, and you're better to get them from specialist resellers who will specify a higher grade than the bog standard ones.
    Switches are a bit simpler - Switchcraft for Gibson-style toggles and CRL for Fender-style lever switches. Oak Grigsby used to be good for lever switches but there seems to have been quite a loss of quality recently.
    Jacks are the easiest of the lot - Switchcraft only. There is simply no point in fitting anything else - they're the best by a wide margin and only slightly more expensive.
    Thanks @ICBM - very clear.
  • @icbm my oak grigsby 3 way pretty well fell apart after six months light use. Replaced it with another but it also started failing - it's very loose and doesn't click into place.
    Now I use a crl, got a 5 way and a 3 way in use. Hoping they last, they're built differently.
