The visual sound buffer is great. A regular boss tuner is also great (I think Pete Thorn did a video that demonstrated how little difference there was between buffers but showed the massive improvement compared to a long chain of crap bypass pedals).
I think i prefer the klon/soul food one ) The visual sound one is pretty good, but it's a bit too obvious that there's a buffer there, if you know what I mean- it overcompensates which results in a slight perceived thinning of your tone (to my ears), whereas the soul food just sounds like you've plugged straight in to the amp. On the other hand, for that same reason, I could see some people thinking the soul food buffer is too subtle )
And yeah good point, check that none of those pedals are already buffere before spending any money.
also the soul food has a little switch inside to swap between buffered and true bypass, so you need to make sure it's set to buffered.
Cornish's buffer is a well-documented circuit too, and I'd urge anyone thinking of buying anything of his to do some non-TGP reading and think very carefully before they do. And then don't.
Edit: god dam autocorrect... But I'm leaving it coz it's funny.
http://revolutiondeux.blogspot.co.uk/2012/02/pete-cornish-ld-1-buffer.html?m=1
