wots your OD of choice.....with a cleanish Marshall?
HootsmonHootsmon Frets: 16060
edited October 2013 in FX
or any old clean amp will do.....but it's the JCM800s me's interested in wae an OD in the "low" channel input
tae be or not tae be
  • monquixotemonquixote Frets: 17869
    What kind of an OD tone are you after?
  • HootsmonHootsmon Frets: 16060
    oh I'm sorted with ODs bro, all Barber stuff....just curious is all ,thanks :)
    Ah, OK I see where you are going.
    Light drive - Liquid Sunshine.
    Heavy Drive - Shredmaster
    actually one of the Boss pedals is BIG with the JCM crew....the OD something or other
  • TimmyOTimmyO Frets: 7699
    For a while I used a BD-2 in to a 70s JMP - sounded huge
    Red ones are better.
  • CirrusCirrus Frets: 8497
    Into the low input, basically anything will sound great. That channel especially in conjunction with g12 65s I find quite smooth so something like a rat or sd-1 is killer.
    I use a stock bd2. Love it. Though I must admit I'm very tempted to try one of fredric's Klones.
  • My faves in this application (clean'ish base amp tone)...
    Low Gain - XTS Precision Multidrive, Timmy
    High Gain - XTS Atomic, Carl Martin Plexitone
    Clean Boost - XTS Tejas and/or Pegasus Boost
    XTS I cant see past them, but for a different flavour I use the above alternatives
    \m/
  • SidNewtonSidNewton Frets: 666
    I used a Fulltone OCD with my 50 watt JCM. It sounds great when using the low input. Just as well because the high input is just too darned loud. Shame because it sounds amazing.
