Forum issues (for me)
axisusaxisus Frets: 28355
Deviant sould that I am, I often type up posts using Outlook at work so that people think I'm doing an email. The problem is that when I post my text, a bunch of jibberish invariably gets posted as well - stuff that neither shows up in the typing box, nor can be deleted afterwards. Any way to fix this?
Also, If I click on 'quote' but then decide not to quote, I cannot get rid of the quote box. Even if I quit and then log on later in the day on a different computer in a different town it is still there to haunt me!! Any fix for that as well?
  • TTonyTTony Frets: 28106
    You'll really be wanting to post this in the "feedback" thread?
  • bertiebertie Frets: 13581
    that happens to all frankus' posts,  but not  'as well'
    It could be that it's been saved as a Draft.
    Check in the left column of your profile page.
  • FretwiredFretwired Frets: 24602
    edited November 2013
    Is it posting the wonderful Microsoft HTML/XML markup [assuming you cut and paste]? Try this - write your post in Outlook, copy the test and open Notepad - copy the text into Notepad then copy it again and post it here. It should now be free of Microsoft crud.
  • jd0272jd0272 Frets: 3867
    Use phone at work to access/post on the good stuff.
    Problem solved.
    I can access TFB on work's server but government tech (for us proles) is frankly shite and the format's all over the place.
  • monquixotemonquixote Frets: 17948
    Win!
  • axisusaxisus Frets: 28355
    Ahhh! Couldn't figure where to put it ....
