Sorry, can't easily post a pic at the moment.
If you want it to be a no-nonsense rock monster I'd probably go with 500K, but the problem is it may make the split and middle tones a bit shrill. You can fix that by using an extra resistor (470K) to give a 250K load in those positions, simply connected in parallel with the middle pickup.
