WTB - Offcut of wood to fill hole from a kahler trem unit
Hello all,
I am looking for some kind of wood (steady!) to fill a trem cavity for a kahler.
I am probably looking at 2 - 3 inch square with a depth of about half an inch.
Does anyone have anything out there?
I'm ideally looking for a variant of hard wood
Cheers
  • Zodiac51Zodiac51 Frets: 340
    @gassage probably has a matching pair of Fender custom shop block-of-wood for filling kahler sized holes. They only made them in black though.
  • TTonyTTony Frets: 28434
    I've got some Ash offcuts from which I could cut off something smaller.  If that'll do, let me know the actual size you need - if I'm going to cut it, I may as well cut it fairly accurately.
    It'll need planing/sanding because it's just offcuts from planks that I was cutting down to body blank size this morning.
  • impmannimpmann Frets: 12766
    I have a chunk of mahogany in the garage that would probably do the job, if the rest of the guitar is made of such.
  • @TTony that sounds perfect sir. I will get some measurement to you mate. Thank you, thats much appreciated.
    @impmann cheers fella, the body its going into is alder or basswood (I think).
    Ultimately its gonna be filled and painted so I think any old thing will do.
    I've got an old roof joist in the shed! ;-)
    Might be best to leave it there though - unless you want an open-air shed of course!
  • I have been known to use Pine door trim before to fill pickup cavities...
    Did it make a difference? I couldn't tell you.
    As long as you align the grain patterns carefully, it'd be hard to tell the difference ...
    PM me the dimensions and your address - that'll save me looking at this thread every time there's an update !
  • Will do sir.
  • SunDevilSunDevil Frets: 511
    Any timber merchant will have an off-cuts bin and will be more than happy for you to have a rummage - guess you'd actually be doing you a favour?
    Never had to pay and you can get some lurvly off-cuts
