This is a possible second entry to the Slide Challenge for 2016, nothing in the rules to say I can't do more than one……..however it will be a challenge keeping it under £100, so it's a possible……
I got this tryuly awful body off someone on here, it was cheap, for a reason,
I was going to put an Epi EB-0 Short scale bass neck onto it and had to fill the 3 point bridge holes I had already drilled…then I had to cover it all up somehow, so thought a while and took a cup-o-tea to the pink one in the sewing room, Eureka moment, she released custody of a "Fat Quarter" of fabric, so I Gorilla glued it onto the top of the body…
I had also routed a recess around the edge of the body previously too
The neck I removed from a previous ratty project 3 string Comicaster
So today the headstock is sprayed satin black, tuners and trees install, neck holes drilled and neck bolted on….
Cost so far Body £30
Neck (used) £10
Tuners (very used!) £8
Fabric £6
Entwhiste P90 (used) £8
Paint £7
Bridge (used) £10
Total so far £79 its gonna be tight!
Stranger from another planet welcome to our hole - Just strap on your guitar and we'll play some rock 'n' roll
