Don't run one with a 1959 without at least 3dB of attenuation, if you're pushing the amp anywhere near overdrive rather than using it strictly clean with pedals - you *will* blow the speakers. Or pull two of the power valves and set the amp to 8 ohms. It's strictly a 100W cab and a 1959 with four power valves will comfortably exceed that even clean.
