Cab advice.
shaunmshaunm Frets: 1624
Has anyone used the Marshall TV cabs with the 4x 25 watt greenbacks in?
I don't know a great deal about cabs. It's to be used with a Marshall 1959 head.
    Yep, they're great, especially with a 1959.
  • ICBMICBM Frets: 72487
    Yes. Nice cab but looks a bit odd. They sound the same as a standard cab give or take a tiny bit 'looser', possibly.
    Don't run one with a 1959 without at least 3dB of attenuation, if you're pushing the amp anywhere near overdrive rather than using it strictly clean with pedals - you *will* blow the speakers. Or pull two of the power valves and set the amp to 8 ohms. It's strictly a 100W cab and a 1959 with four power valves will comfortably exceed that even clean.
