As far as I know Weber do ship directly to the UK.
In the end, I thought it was ok. At lower volumes there was basically no difference between it and a valve rectifier in my AC30. At higher volumes, once the power section was being pushed into compression, I thought the copper cap was slightly stiffer, which equated to a little extra tightness, and a slightly brighter sound. I preferred the GZ34, so back in it went.
Bandcamp
Spotify, Apple et al
The Sovtek one is much more bullet proof and when I AB'd them, the voltages were the same - http://www.hotroxuk.com/solid-state-rectifier-ssr.html
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
I haven't seen a Weber one fall apart, but presumably it's due to the glue breaking down with heat over time, since they do get hot.
But WHY Copper? Surely the rectifiers do not need heat sinking? And yes would not have hurt to use high temp' epoxy!
Dave.
Bandcamp
The SS rectifiers don't get hot, but the series resistors emulating the resistance of a valve rectifier certainly do.
Epoxy is an excellent thermal insulator, so not the best choice.....
There are thermally conducting epoxies.
Dave.
The problem is that thermal and electrical conductivity are often related!
Rift Amplification
www.riftamps.co.uk
Why worry about a thin smear of epoxy when there is a big lump of un earthed copper?
Diamond iirc is an excellent conductor of heat but is an electrical insulator. Some ceramics have similar properties.
Dave (just off to check me facts!)
Yes, diamond has the highest thermal conductivity of any known substance. It is also and insulator. So, diamond dust in an epoxy matrix. Job's a good'un.
Dave.
Problem solved .
