Ted Weber WZ34 Copper Top Rectifiers ? ? ?
maw4neumaw4neu Frets: 562
Are these available in the UK ???? . . . They sound like a "must" for AC30 and Bassman owners . . .
Id just like to point out that, despite all the video and DNA evidence, it genuinely wasn't me, your Honour  !
Feedback : https://www.thefretboard.co.uk/discussion/58125/
  • ICBMICBM Frets: 72769
    I'm not sure, but they would certainly be a very good idea in any modern valve-rectified amp which has the standby switch in the wrong place, so it stresses the rectifier - like the AC30CC, Orange AD30 etc. (Although in my opinion the Orange sounds better with a plain non-valve-emulating solid-state rectifier.) The Bassman does actually have a suppressor cap upstream of the standby switch so it isn't quite as bad, and original AC30s with no standby switch don't really benefit.
    As far as I know Weber do ship directly to the UK.
  • CirrusCirrus Frets: 8495
    I was particularly impressed when I tried to pull the one I had out the GZ34 socket and the copper casing came away, exposing the naked components inside and leaving them connected. But that would have been around 2010, I guess.
    In the end, I thought it was ok. At lower volumes there was basically no difference between it and a valve rectifier in my AC30. At higher volumes, once the power section was being pushed into compression, I thought the copper cap was slightly stiffer, which equated to a little extra tightness, and a slightly brighter sound. I preferred the GZ34, so back in it went.
  • RiftAmpsRiftAmps Frets: 3183
    edited August 2017 tFB Trader
    From experience, the Weber ones always fall apart (as mentioned above).
    The Sovtek one is much more bullet proof and when I AB'd them, the voltages were the same - http://www.hotroxuk.com/solid-state-rectifier-ssr.html
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    The Sovtek one doesn't contain any resistance though, surely… it's a plain solid-state rectifier rather than a valve-emulating one.
    I haven't seen a Weber one fall apart, but presumably it's due to the glue breaking down with heat over time, since they do get hot.
  • MartinBMartinB Frets: 218
    Just a thought, but I'm a bit uneasy about the choice of an un-grounded copper casing for a device handling high AC and DC voltages that lives outside the chassis of an open-backed combo.  Would that comply with any sort of safety certification?  And if they're prone to falling apart, that makes them even less appealing.
    It is worrying, yes. If they're built with the copper can isolated from the internals that's one thing, but if they fall apart it's quite another...
  • ecc83ecc83 Frets: 1640
    But WHY Copper? Surely the rectifiers do not need heat sinking?  And yes would not have hurt to use high temp' epoxy!
    Dave.
    Kind of amusing that when you google image search for "Weber Copper Cap", the first three results show the naked innards.
  • jpfampsjpfamps Frets: 2734
    Dave.
    The SS rectifiers don't get hot, but the series resistors emulating the resistance of a valve rectifier certainly do.
    Epoxy is an excellent thermal insulator, so not the best choice.....
  • DJH83004DJH83004 Frets: 196
    That's a very valid point Martin any extraneous metal part on a class 1 piece of equipment (which the majority of guitar amps are) should be at earth potential, An internal fault or physical damage could render the outer casing live.
    jpfamps said:
    Dave.
    There are thermally conducting epoxies.
    Dave.
    How electrically isolating are they? I thought they contained metal dust as the filler.
    The problem is that thermal and electrical conductivity are often related!
    Correct, no resistance in the Sovtek/TAD one, just 6 x 1N4007 in a neat little sealed unit.
    Rift Amplification
    www.riftamps.co.uk
    Why worry about a thin smear of epoxy when there is a big lump of un earthed copper?
    Diamond iirc is an excellent conductor of heat but is an electrical insulator. Some ceramics have similar properties.
    Dave (just off to check me facts!)
    Yes, diamond has the highest thermal conductivity of any known substance. It is also and insulator. So, diamond dust in an epoxy matrix. Job's a good'un.
    Dave.
    Because if the epoxy is conductive and is in contact with any of the internal components, then the copper can will become live at +470V or so!
    Problem solved :).
