Another sort of practice amp question. I have a Vox AV30 at home but I want something that I can take away with me. (Needing to spend quite a lot of time at a relatives in Bristol ATM) so quiet and not take up too much space in the car but ideally will be loud enough to hold its own in the practice room at jam sessions to save me carting the AV30 along.
I was thinking of a small valve amp with 0.5 or 1 watt setting, or, would a small modeller be better and which of either comes recommended please?
Or is there just not one solution and I need one for jams and another to take away?
Cost is not the primary consideration, but bearing in mind the more occasional use I don't really want to spend more than a couple of hundred or so.
Just because you're paranoid, don't mean they're not after youIf you're wanting something smaller than the Katana, the Yamaha THR amps probably the best bet? Or if you fancy a valve amp you could go with a Bugera V5 - pretty cheap, and has attenuation down to 1 watt. Probably not the greatest tone or quality in the world, but not bad for the price.
Has anyone used a Bugera v5 infinitum or a Juketone True Blood?
Thanks @Dontgiveupyourdayjob
A Laney VC15 is a good bet, or any of the modern modellers
Light, compact and absolutely craps on the ac4tv I had. Goes bloody loud with its own 8" speaker but also has a speaker output which can give even more volume. Not suitable for metal type stuff though.
It has a less than 1w input and a 15w input.
I used it in my band for 3 years. Cracking amp. Needs a speaker upgrade though. Celestion V works really well.
I've not tried a Code yet but it does sound like it might be suitable too.
How about a s/h Roland Cube 20 or 40? Fairly lightweight and may have master volume or low wattage setting depending on the exact model.
