Quiet enough for home but loud enough for jams.
TADodgerTADodger Frets: 211
Another sort of practice amp question. I have a Vox AV30 at home but I want something that I can take away with me. (Needing to spend quite a lot of time at a relatives in Bristol ATM) so quiet and not take up too much space in the car but ideally will be loud enough to hold its own in the practice room at jam sessions to save me carting the AV30 along.
I was thinking of a small valve amp with 0.5 or 1 watt setting, or, would a small modeller be better and which of either comes recommended please?
Or is there just not one solution and I need one for jams and another to take away?
Cost is not the primary consideration, but bearing in mind the more occasional use I don't really want to spend more than a couple of hundred or so.
«134
  • I know this is a very boring answer on almost all these threads. But Boss Katana.
  • Isn't the Katana 50 close in size and weight to my AV30 and I would guess a Katana Mini wouldn't cut it at a jam.
  • I've got a HT1-R that has great tone and would crank if needs be. What about the VOX AC4TV?
  • LegionreturnsLegionreturns Frets: 7965
    edited September 2017
    I'm really very impressed since switching to the Katana head. The internal speaker is great for practice...but put it through a 2x12 and it's a totally different animal! Add all the other features of the Katana in and you can't go wrong.
    Would the HT1-R be loud enough for jams? HT5-R might be a better option, but possibly out of budget?
    If you're wanting something smaller than the Katana, the Yamaha THR amps probably the best bet? Or if you fancy a valve amp you could go with a Bugera V5 - pretty cheap, and has attenuation down to 1 watt. Probably not the greatest tone or quality in the world, but not bad for the price.
  • I'm really very impressed since switching to the Katana head. The internal speaker is great for practice...but put it through a 2x12 and it's a totally different animal! Add all the other features of the Katana in and you can't go wrong.
    I did look at this, but the head is still quite large to take away and needs a cab for decent volume.
    Has anyone used a Bugera v5 infinitum or a Juketone True Blood?
    Thanks @Dontgiveupyourdayjob ;
  • Egnator Tweaker 15 head if you have a cab to play through at rehearsal? Excellent master volume for quiet practice and loud enough to jam with a drummer. And cheap - or the Jet City head that was for sale here for peanuts?
  • Anything with a decent master volume. Probably not a 1W valve amp, which generally have all the same problems as boing valve amps while also being cheaply made.
    A Laney VC15 is a good bet, or any of the modern modellers
  • JezWyndJezWynd Frets: 6088
    The Laney Cub 10 is very nice. 10" speaker. With 2 x 6V6's, it can put out quite a bit of volume, esp if you use the ext cabinet socket.
  • What about a Marshall Code 25?  They are seriously wee and I've played one belonging to another fretboarder and they have some nifty tones.
    I guess it depends who you are jamming with and what gear they have  ;)
    i have considered a code 25, how do they compare with small valve amps?
  • Flanging_FredFlanging_Fred Frets: 3035
    If you can find one, how about a s/h Vox Pathfinder 15r.
    Light, compact and absolutely craps on the ac4tv I had. Goes bloody loud with its own 8" speaker but also has a speaker output which can give even more volume.  Not suitable for metal type stuff though.
  • If you can find one, how about a s/h Vox Pathfinder 15r.
    Light, compact and absolutely craps on the ac4tv I had. Goes bloody loud with its own 10" speaker but also has a speaker output which can give even more volume.  Not suitable for metal type stuff though.
    Thanks, but still a bit big. I suppose my original feeling is slowly being answered, you can't have a small transportable amp plus jamming volume / tone in one amp. Closest so far for size, weight and performance seems to be the Code 25.
  • AdamskiAdamski Frets: 1278
    I doubt the Code 25 can hang with a drummer. Could always mic it I guess
    OK, thats useful. what might hang with a drummer and still do quiet-ish home sounds?
  • Laney cub 12.
    It has a less than 1w input and a 15w input.
    I used it in my band for 3 years. Cracking amp. Needs a speaker upgrade though. Celestion V works really well.
    If that's too big then the next thing I would say is the ZT lunchbox (or lunchbox junior). Tiny and monstrously loud if you want it. You'll probably want a pedal or two with it though.
    I've not tried a Code yet but it does sound like it might be suitable too.
  • HAL9000HAL9000 Frets: 9696
    Good shout. Having heard Fred's Pathfinder, I can vouch for how ridiculously loud it is for a solid-state amp rated at 15W. Not too big either.
    How about a s/h Roland Cube 20 or 40? Fairly lightweight and may have master volume or low wattage setting depending on the exact model.
