A well cut nut is the thing that is required, but does it actually make a difference what it is made of? I was thinking that you would only see any real benefit when playing open strings, and that isn't really all that often most of the time. Does it really make that much of a difference?
On the other hand, I bought a warmoth neck with a bone nut a couple of years ago. The nut was the worst cut I have ever seen - it looked like it was done with a hack saw, literally! The guitar played fine, but the nut looked such an abortion that I had it replaced. I can't recall off the top of my head what I had it replaced with, but it wasn't bone. Anyway, the neck just lost something of its mojo afterwards.
I'm led to believe they do..but urm.. I don't actually know. I've swapped and cut a few nuts from bone etc but not noticed too much of a difference.. but I don't swap nuts unless I have to. But I struggle with what I believe with electric guitars..I try and stick by Faraday's law as urm it makes sense aha.
the only thing that should matter ever is the vibration of the string. so id imagine if it's soft it might cause the string to dampen.
so I would say yes. But not the material.. the density.
If a brass nut has the same density as bone than it would sound the same if all other variables are the same.
There's just some other videos I've seen him in.. whilst he is knowledgeable most of his examples where he's breaking them down to layman's terms are just completely wrong.
Instagram
But if I bought Pearly Gates (the real one) from Billy Gibbons, and the top two open strings were pinging a bit I would probably be weighing up the risk of changing the sound with a new nut (10% risk) against the risk of changing the sound with 2 tiny squares of Aluminium Foil in the nut slots (0.3% risk).
Just Sayin....
There used to be lengthy arguments on TGP about how nut material affects all the other notes, but I can't imagine anyone claiming that a plastic 6th fret would do the same.
People make a massive deal out of this issue, claiming this is better than that, but none of it is as critical as how well its been cut.
As to Mr PRS . I am a like. Just think how he gave Fender and Gibson a massive wakeup call to the crap they were churning out until he hit the scene. Still keeping them on their toes too... I am sure his passion is genuine
Does a locking clamp behind the nut alter the sound of all the notes on a guitar? Or a zero fret?
I think sometimes we look for little bits of magic in guitar construction, but sometimes there really are things which don't actually matter.
Yes in both cases.
