Anybody gigging or rehearsing with a Zoom G3XN??
Strat_a_tat_tatStrat_a_tat_tat Frets: 2048
in FX
If so... how's it working out for you?  Good... bad... wish you'd gone with something different?
Many thanks.
  • Strat_a_tat_tatStrat_a_tat_tat Frets: 2048
    Anybody????
    It's lonely here in G3XN land.
  • midlifecrisismidlifecrisis Frets: 1229
    i used the predecessor the G3 for a couple of years as my gigging pedalboard. liked it a lot,
    Thanks.  Was it easy to switch patches and make adjustments when you were at a gig.... or did it require scrolling through menus etc.?
    Looks like some of the small multi-FX are more suited to home use / recording. I'm hoping that's not the case with the Zoom.
    Thanks.
    the way i used it was that i only had 3 or 4 patches, never saw any point in anymore. , you can have up to 6 effects on each patch.   as i only had 3 or 4 patches it was very easy to scroll between them between songs. I did find the effects very good, i only stopped using it when i started using my Katana and the onboard effects.
    Great. Many thanks for the info.  As you say, even using only 3 or 4 patches (with up to 6 effects in each patch) still gives a lot of possibilities... and should cover a fair few songs.
    I use an analogue board with various pedals... so I guess that means I've only got one patch! (Unless I get on my hands and knees between songs... and turn a few dials.  Mind you - that's better than having to scroll through menus!).
    Again... thanks for your help.
    as you say, if you only use  3/ 4 patches you can put them so they are consecutive yo each other so scrolling is minimized, plus you can name them ie  clean, heavy, sweet child o mine. hope that makes sense
    must point out, although a patch can have 6 effects, you can only see 3 at a time without scrolling sideways. ie in a song you can only practically use 3 at a time. i never found this a problem but you should be aware of that
    edited March 7
    Thanks.  Have a 'Wisdom' or four.  ;-)
  • John_AJohn_A Frets: 1476
    I've got a G3n bought as a Helix backup, reheared with it and it sounded great, but just set up three patches and the ability to switch in and out a delay, nothing fancy
    Do me a favour and like this:
    https://www.facebook.com/MarkedCoversBand
  • beerbeer Frets: 24
    I have one on my board and really like it. It's become surrounded by pedals that do a better job than it though. I still use the amp and cab sounds and it has a nice acoustic sim on it.
  • VoxmanVoxman Frets: 2039
    I thought you could have a chain of 7 fx (9 in the g5n)?
    @John_A how does it compare tonally to the Helix...is the amp modelling any good?
    It sounds great.  I found it didn't feel as good, it's hard to explain, but very good indeed, if you want mine for 60% of new price drop me a pm, have an AMT SS11A that'll do as a backup, and hopefully won't need it anyway (crosses fingers). It's boxed and hardly used
    Appreciate the thought but for now I'll stick with my Tonelabs. I had a Zoom G5 for a while but sold it. Partly it was because the limited switching made it useless for gigging, partly because the menu scrolling drove me mad, and partly because with all its modern modelling and effects I couldn't get it to sound as good as my Tonelabs.
    But the new Zoom units have way better switching functionality and the amp modelling is supposed to be improved...and the G3nx and g5n are more compact and lighter than the Tonelab LE or SE. If I did buy one to try it would have to be one of these though as I need the expression pedal.
    possibly, but i was talking about the G3.
  • paulnb57paulnb57 Frets: 1150
    Ive just bought a G3n and although early days I'm quite impressed, this is my first ever programmable multi effects and learning to edit etc has been a steep learning curve, I find most of the presets a bit over the top, preferring a bit of subtlety, but they make a good starting point edit...
