Gone away to the tip: IT equipment 8-way ethernet switch (hub)
fandangofandango Frets: 2204
edited July 2018 in Misc £
One for you IT bods out there, here's my no-longer-used fast ethernet hub.
Basiccally I'm giving this away - free upon collection.
If you can't make it in person, then postage is £8.50 (based upon ParcelForce).
Basically, I just want to cover my costs of posting via Royal Mail or ParcelForce from my nearest Post Office.
Now chucked out.
Thanks for reading.
  • TravisthedogTravisthedog Frets: 1846
    So when I had my extension built I had cat5 cable run from my skyhub up into the loft and across to all the new rooms. I guess this is what I need to connect it all up isn't it
    If so I'll take it but you'll have to post mate
  • mrkbmrkb Frets: 6837
    Just be aware 100 mb/s isn't that fast nowadays, that’s slower than typical Wi-fi speeds. Most switches are now gigabit 1000 mb/s, and are only £30 ish.
    Karma......
    Ebay mark7777_1
  • fandangofandango Frets: 2204
    That is true.
    @Travisthedog - I wouldn't have a problem if you decided this switch/hub wasn't for you.
  • robinbowesrobinbowes Frets: 3044
    I’d love to see you get 100mbps over wifi.
    You might possibly manage it if you have 802.11ac and you're sitting on top of the WAP and using only one device.
    100mbps is fine unless you're moving around large volumes of data on your internal network.
    R.
    Hop skip and bump
    R.
    Well said mate and spot on
    Its also worth bearing in mind that a computer is only as fast as its slowest component.
  • BodBod Frets: 1315
    R.
    Which is nearly always the user...
    nearly always <facepalm>
