Ive used a combo of coarse/fine rasps, the microplanes and shoe-shiner-with-sandpaper approach, which has worked well.
From the bottom: Wood rasp, Japanese (actually Czech) toothed rasp, wire brush to keep rasps clear, surform, spokeshave, templates and micrometer. Conclusions: Surform is best at removing wood; spokeshave gives the best finish; only the rasp can handle the volutes at each end of the neck. For finishing I prefer a cabinet scraper, particularly over the volutes where sandpaper can leave the surface smooth but bumpy.
These Shinto rasps are good - a lighter cut and an evil side -
https://www.axminster.co.uk/japanese-saw-rasp-384015
Plus spokeshaves, rasps, files, scrapers, cylinder blocks for sanding, etc. Got some 0.25mm scrapers than bend easily, good for curved things.
I finish off with shoe shine sanding and/or scrapers
Instagram
(formerly customkits)
I Anyhows purchased this rather large 1/2" router bit from aliexpress (was about £12)
Set it up in a overarm jig i bult and im building a few test necks with it now for a headless 6'er
this one is cut to thickness of 14.6mm with a final neck thickness of 19.6mm,
ive done few tests with leaving more shoulder in not just using the fretboard as the shoulder and they all feel great,like a modern wide D feel with a slight flat center section,reminds me of my HM strat necks.takes about 3 min's from thicknessed blank to profiled neck.
Works very well and is a really delicate tool if needs be or a complete hooligan if lots of material is needed to be removed. I do use the random orbital sander to finish the final carve just in case I get a bit trigger happy
Check out Crimson Guitars for videos on him using this method.
Ta
He's a complete tool who shapes necks.
