good tool for neck shaping?
axisusaxisus Frets: 28339
What's a good tool for neck shaping. My current stuff doesn't work very well and it takes an age.
Preferably something that can be bought in the UK
  • KalimnaKalimna Frets: 1540
    edited May 2018
    Do you mean beyond rasps and microplanes?
    Ive used a combo of coarse/fine rasps, the microplanes and shoe-shiner-with-sandpaper approach, which has worked well.
  • SporkySporky Frets: 28485
    Spokeshave and scrapers.
  • RolandRoland Frets: 8731
    Everyone likes a picture:
    From the bottom: Wood rasp, Japanese (actually Czech) toothed rasp, wire brush to keep rasps clear, surform, spokeshave, templates and micrometer. Conclusions: Surform is best at removing wood; spokeshave gives the best finish; only the rasp can handle the volutes at each end of the neck. For finishing I prefer a cabinet scraper, particularly over the volutes where sandpaper can leave the surface smooth but bumpy.
  • CorvusCorvus Frets: 2928
    These Shinto rasps are good - a lighter cut and an evil side -
    https://www.axminster.co.uk/japanese-saw-rasp-384015
    Plus spokeshaves, rasps, files, scrapers, cylinder blocks for sanding, etc. Got some 0.25mm scrapers than bend easily, good for curved things.
  • WezVWezV Frets: 16735
    Yeah, once I have roughed in the contours on a sander the Shinto rasp does 90% of the carving work for me.
    I finish off with shoe shine sanding and/or scrapers
  • axisusaxisus Frets: 28339
    Many thanks all. @Roland thanks for the pix! very helpful!
  • octatonicoctatonic Frets: 33805
    Herdim rasps and a Veritas spokeshave.
    I'm the same as @Sporky ; - spokeshave and scrapers. I also use a curved micro- plane for the volute and heel areas
  • DanielsguitarsDanielsguitars Frets: 3297
    Shinto rasps are great, as already said it'll do most of the work then just scrapers and sandpaper
    www.danielsguitars.co.uk
    (formerly customkits)
  • GizmoGizmo Frets: 1078
    Ive worked with rasps/spoke shaves cabinet scrapers ect ect,great fun but can be slow going if you have a lot or mertial to remove.
    I Anyhows  purchased this rather large 1/2" router bit from aliexpress (was about £12)
    Set it up in a overarm jig i bult and im building a few test necks with it now for a headless 6'er
    this one is cut to thickness of 14.6mm with a final neck thickness of 19.6mm,
    ive done few tests with leaving more shoulder in not just using the fretboard as the shoulder and they all feel great,like a modern wide D feel with a slight flat center section,reminds me of my HM strat necks.takes about 3 min's from thicknessed blank to profiled neck.
  • Marktigere1Marktigere1 Frets: 101
    I use an Angle Grinder and flap disc method.
    Works very well and is a really delicate tool if needs be or a complete hooligan if lots of material is needed to be removed. I do use the random orbital sander to finish the final carve just in case I get a bit trigger happy ;)
    Check out Crimson Guitars for videos on him using this method.
    Ta
  • GassageGassage Frets: 30929
    Email Mark D Phillips.
    He's a complete tool who shapes necks.
