Gumtree Content: The height of laziness...
HarrySevenHarrySeven Frets: 8033
...could well be this...
Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • FunkfingersFunkfingers Frets: 14639
    Simple soldering repair ... or a total lack of understanding about switching TRS jack sockets.
    IMHO, the gig bag is worth more than the Shine "bass".
    To be honest that would really annoy me.
    I don't think I could ever go for an active bass or guitar purely on the basis that I wouldn't want to have to think about changing the battery.
    Shame because I quite fancy an Epiphone thunderbird and the colour I like comes active.
  • BloodEagleBloodEagle Frets: 5320
    You have to admire the guy in a way
  • Jack_Jack_ Frets: 3175
    Changing is infrequent, and if you get a couple of rechargeables on rotation it's nothing.
  • WezVWezV Frets: 16830
     it’s not uncommon for people to turn up with a bass they have had years that has stopped working.
    You ask if they have changed the battery to be greeted by the same response every time.
    “What battery”
    I suspect that the issue with the eBay auction bass is that somebody has performed a bodge soldering repair to the output jack socket.
    On many active stringed instruments, the three contacts on the output jack socket are configured as;
    Tip = "Hot" output.
    Ring = Ground for onboard battery power (this connection is broken whenever the audio lead is removed).
    Sleeve = System ground.
    If the battery ground is mistakenly connected to the system ground, the battery power is constantly being drawn - even when the output cable is disconnected.
    Tip = "Hot" output.
    I once bought an SG Special where rather than fit a proper jack and get it wired, the guy put an on/off toggle switch coming through the rear cavity plate.
  • richardhomerrichardhomer Frets: 24859
    Cheap though - even if it does need a new battery....
