https://www.amazon.co.uk/dp/B01DVVY81Q?ref_=pfb_cd29683h2g5e82chikeb1515006&tag=hydfbook-21&ascsubtag=pfb-P01-V01-O3-X92-HI-HS1GT8&th=1
Also you are relying on your broadband connection working 100% of the time - do you have that trust in your setup?
I’d for for something well hidden and simple recording to a drive and maybe a couple of independent WiFi smart cams so you can get push notifications to your phone etc. Best of both worlds.
Thats my plan anyway.
Cheers,
Arlo does push notifications to your phone, you can insert a pen drive or USB HDD to the base units, and it records it all locally as well as copying all clips to the cloud for the free 7 day storage
I got the Arlo Pro 2. Supposed to be 1080p, but I think not. Certainly good though
Batteries can last months. They are rechargeable, just plug in the adaptor like a phone for a few hours
Camera has a strong magnet in the back, can stick to quite a lot of things, or the little metal mounting dome they supply
you can buy camouflage skins for them
Arlo v1 uses disposable camera batteries, and I think would cost a lot to run, do not buy I think
Arlo Pro is 720p probably usable enough
keep an eye on amazon using camel camel camel, there have been some major 1-day discounts
I wonder if the Arlo will notify you when a camera loses connection? In which case, that might be enough to alert me and then I could have some other forms of security and/or CCTV.
However, how does that help? The Arlo cameras are wireless, it's the base station that's wired into the LAN from your router. If the internet connection is gone, how could the base station send anything?
You could use a mobile connection, and convert it into a LAN cable into the Arlo, but remember that Arlo loads everything to the Netgear cloud, so that's a lot of traffic
they are great though, you can move them indoors, have them only active when your phone is away from the house, have them trigger the alarm in the base station (smoke alarm type noise)
