Decent wifi cctv?
DougDoug Frets: 172
As above, anyone know of a decent quality wifi home cctv system?
Tia.
  • roundthebendroundthebend Frets: 1139
    I've seen and heard good things with Netgear Arlo. I'm resisting the temptation to buy a kit right now, the 4 camera system is £330 on Amazon. They do a "pro" version which is Full HD I believe but quite a bit more money.
    https://www.amazon.co.uk/dp/B01DVVY81Q?ref_=pfb_cd29683h2g5e82chikeb1515006&tag=hydfbook-21&ascsubtag=pfb-P01-V01-O3-X92-HI-HS1GT8&th=1
  • IamnobodyIamnobody Frets: 6906
    edited June 2018
    I wouldn’t base a system completely on WiFi. With all the WiFi gadgets available now burglars will soon be chopping broadband cables before they enter properties. I would if that was my line of erm...work!
    Also you are relying on your broadband connection working 100% of the time - do you have that trust in your setup?
    I’d for for something well hidden and simple recording to a drive and maybe a couple of independent WiFi smart cams so you can get push notifications to your phone etc. Best of both worlds.
    Thats my plan anyway.
    Previously known as stevebrum
  • DefaultMDefaultM Frets: 7347
    I don't understand the concern. They'd cut through the cable, my porn would start buffering and then they'd hear me coming down the stairs  to reset the box and be scared off.
  • DougDoug Frets: 172
     @Iamnobody Could you explain exactly what components I would need to achieve this.
     Cheers,
  • ToneControlToneControl Frets: 11940
    because you'd be wielding a frightening weapon
    Arlo works well
    Arlo does push notifications to your phone, you can insert a pen drive or USB HDD to the base units, and it records it all locally as well as copying all clips to the cloud for the free 7 day storage
    I got the Arlo Pro 2. Supposed to be 1080p, but I think not. Certainly good though
    Batteries can last months. They are rechargeable, just plug in the adaptor like a phone for a few hours
    Camera has a strong magnet in the back, can stick to quite a lot of things, or the little metal mounting dome they supply
    you can buy camouflage skins for them
    Arlo v1 uses disposable camera batteries, and I think would cost a lot to run, do not buy I think
    Arlo Pro is 720p probably usable enough
    keep an eye on amazon using camel camel camel, there have been some major 1-day discounts
    If we're worried about network cables being cut, then I guess a camera which can use a mobile network would be ideal. Add in battery backup and it'll be fairly tamper-resistant.
    I wonder if the Arlo will notify you when a camera loses connection? In which case, that might be enough to alert me and then I could have some other forms of security and/or CCTV.
    the arlo base station will tell you when a camera has low battery. Probably if it goes out of range too, I'll check
    However, how does that help? The Arlo cameras are wireless, it's the base station that's wired into the LAN from your router. If the internet connection is gone, how could the base station send anything?
    You could use a mobile connection, and convert it into a LAN cable into the Arlo, but remember that Arlo loads everything to the Netgear cloud, so that's a lot of traffic
    Also remember that the arlo is normally just magnet-mounted, so if in reach could easily be stolen, if someone realised that
    they are great though, you can move them indoors, have them only active when your phone is away from the house, have them trigger the alarm in the base station (smoke alarm type noise)
    The magnet-mount is one of the biggest turnoffs for me. I know you can buy screw-mounts too. Actually, the problem I have is that to position a camera covering my front door will always mean having it within easy reach so I either need something which is securely attached, or very discrete.
