Lack of volume and weedy tone - certainly inferior to my 5 watt Champ clone with a 8" speaker!
So I power down the amp and have a butchers at the valves to see if that's the problem.
Turns out the valves are not the correct spec.
Instead of a pair of 12AX7s there's a 12AT7:
https://i.imgur.com/vJfdR3P.jpg
And a 12AU7:
https://i.imgur.com/lZGJ1L4.jpg
https://i.imgur.com/bMXvgtp.jpg?1
So here are the inevitable questions!:
1. Can EL34s and EL84s be swapped in Pro Juniors without causing any problems?
2. The original speaker has been swapped out for a Celestion G10D-25, is this a decent speaker or is it on par with the dreaded 'Tube 10'?
The Eminence Rajin' Cajun seems to be a popular speaker upgrade for these.
Sounds like you need to be having words with the eBay seller though...
It's ok, it's not as bad as a Rocket 50 but it's not a "Nice" speaker really.
Maybe someone with more insight than me knows better but I wasn't mad keen on it.
Celestion do a 10" version of V30 which I heard was excellent but I've not *heard* one so can't say for sure.
I've heard lots of good reports about the Ragin Cajun too.
The Celestion G10 Vintage is like a small V30, only even more so. I wouldn’t recommend it unless sheer volume is the only purpose - it will take away all the nice top-end sparkle and make the clean sound a bit dirty even when the amp isn’t.
I wouldn’t pick a Celestion at all, in fact - a Jensen, Eminence Patriot series or Weber would be much better - American amp, American (voiced) speaker...
The Ragin’ Cajun is excellent if you want a really big sound.
