NAD: Fender Pro Junior (couple of questions too!)
longjawlongjaw Frets: 423
edited August 2018 in Amps
This has just arrived, a bit of a bargain (maybe!) from eBay:
https://i.imgur.com/KRumkcQ.jpg
Couple of immediate issues though, the seller left the valves in the amp, they've been damaged in transit:
https://i.imgur.com/cRRqG8p.jpg?1
I had to re-straighten the bent pins with some pliers, so no harm done there.
Gonna need a new plug too I think:
https://i.imgur.com/1squl4s.jpg
  • longjawlongjaw Frets: 423
    After re-seating the valves, I fire the amp up - power light comes on fine. I stick the volume on 5 and tone on 4, strike a big open 'E' chord on my Strat and .... I'm thoroughly underwhelmed. :anguished:
    Lack of volume and weedy tone - certainly inferior to my 5 watt Champ clone with a 8" speaker!
    So I power down the amp and have a butchers at the valves to see if that's the problem.
    Turns out the valves are not the correct spec.
    Instead of a pair of 12AX7s there's a 12AT7:
    https://i.imgur.com/vJfdR3P.jpg
    And a 12AU7:
    https://i.imgur.com/lZGJ1L4.jpg
    Also, instead of EL84s it has a pair of EL34s, one isn't labelled while the other appears to be made by 'Bentley' and is labelled 'Foreign':
    https://i.imgur.com/bMXvgtp.jpg?1
    A quick valve swap with a pair of AX7s and EL84s, re-try for a couple of minutes and it sounds much better!
    So here are the inevitable questions!:
    1. Can EL34s and EL84s be swapped in Pro Juniors without causing any problems?
    2. The original speaker has been swapped out for a Celestion G10D-25, is this a decent speaker or is it on par with the dreaded 'Tube 10'?
  • AlnicoAlnico Frets: 4616
    I can't help with the valve questions but that speaker is what was factory fitted to the Marshall 'Lead 12' in the 80's.
    Here's a pic of my old one from an '85 Lead 12.
    They're not amazing speakers IMO.
    Cheers bud, thought so.
    The Eminence Rajin' Cajun seems to be a popular speaker upgrade for these.
    Funny, I've heard the opposite :) But I'm not experienced in 10" speakers, I've never been hugely impressed by my Lead 12, with one of these speakers, until I ran it through a 2x12 and it sounded waay better.  But I digress...
  • lovestrat74lovestrat74 Frets: 2530
    Err,.. I'd be inclined to return it if none of the above was mentioned in the description..
  • koss59koss59 Frets: 849
    That’s not an EL34 it’s an 84 with part of the 8 rubbed off.
    Facebook.com/nashvillesounduk/
    You might be on to something there! :-)
  • I sold one of these recently and it sounded glorious....
    I can't help on the tech but I owned an old Tweed Junior and it was loud and sounded great. Better then the Blues Junior IMHO.
    Hope you sort your amp out.
  • simonksimonk Frets: 1467
    Pro Jr’s are terrific little amps and the Ragin Cajun is an excellent choice for a speaker upgrade.
    Sounds like you need to be having words with the eBay seller though...
    That's how I determined mine wasn't much cop.
    It's ok, it's not as bad as a Rocket 50 but it's not a "Nice" speaker really.
    Maybe someone with more insight than me knows better but I wasn't mad keen on it.
    Celestion do a 10" version of V30 which I heard was excellent but I've not *heard* one so can't say for sure.
    I've heard lots of good reports about the Ragin Cajun too.
  • p90foolp90fool Frets: 31629
    I can't see the image, but you can't swap EL84s for EL34s, they're completely different sockets.
    Yep, thats what I thought - @koss59 has nailed it by saying part of the text has been rubbed off so it now reads EL34 instead of 84 ;)
  • ICBMICBM Frets: 72484
    As already said, it’s crap - much worse than a Tube 10. Pretty much any other speaker is better.
    The Celestion G10 Vintage is like a small V30, only even more so. I wouldn’t recommend it unless sheer volume is the only purpose - it will take away all the nice top-end sparkle and make the clean sound a bit dirty even when the amp isn’t.
    I wouldn’t pick a Celestion at all, in fact - a Jensen, Eminence Patriot series or Weber would be much better - American amp, American (voiced) speaker...
    The Ragin’ Cajun is excellent if you want a really big sound.
    Rajin' Cajun ordered - cheers all!
  • Out of curiosity, what made you go for the Pro Junior over a Blues Junior?
    Pro Juniors get universally positive reviews, while I've read plenty of negative ones about Blues Juniors.
    The Pro Jr just sounds better, although obviously has fewer features.
