power to PA fault?
This may not be something anyone can help with without seeing the unit, but a friend has handed be a yamaha power mixer which will switch on for all of 1-2secs (lights up fan runs) then switches off. Is this a glaringly obvious fault and easy fix or is this a give it back to said friend and tell them to take it to a professional?
Any help or advice greatly appreciated as always.
  • ICBMICBM Frets: 72329
    Take it to a professional. It almost certainly has a shorted power transistor or other major component which is causing the protection circuitry to shut the amp down.
    Whether it's easily or economically fixable depends on the age and type of power amp and power supply design. Older ones can actually be easier.
  • Cool, thank you very much. I'm not quite sure why they think "he knows how to plug a guitar into an amp he'll be able to fix things" so I'll point them in the right direction.
  • Yup lights and fan on a separate low power circuit effectively, so when the higher power circuit starts the safety elves come out and shut it all down. Job for a pro.
    www.maltingsaudio.co.uk
