NCD
No not No Claims Discount but New Computer Day :)
Raspberry Pi. It worked, straight out of the box, with a new monitor from PC world. The old laptop is dead - shame because there are a few files on it I want to keep.
Monitor from PCW 'cos they offered a 3 yr Replace it if it Screws UP (as many times as you like) warranty for £20.
And you get gcc, make, and loads of other software with the Pi :)
  • axisusaxisus Frets: 28339
    Raspberry pi? Make? GCC? we live in different worlds
  • I was hoping for a new cat day.
    Anyway - congrats on new toy. Have fun!
    Roobi would never allow that!
    The keyboard is small and a bit different, which I don't mind - but I can't find the pipe symbol (aka vertical bar).
    Shift-3 echoes as pound
    backslash echoes as hash
    pipe echoes as tilde
    blip echoes as blip
    ears echoes as at
    shift-2 echoes as ears
    ... but where's the pipe?
  • Shift backslash ?
  • Shift backslash ?
    gets you a tilde
  • NiteflyNitefly Frets: 4924
    Alt gr backslash does it on my chromebook, Phil.
  • octatonicoctatonic Frets: 33806
    Just restore from the backups that that you have been keeping. :)
  • UNSHIFTED
    top row  `1234567890-=
    first letter row qwertyuiop[]#
    2nd letter row asdfghjkl;'
    lower letter row zxcvbnm,./
    SHIFTED
    ¬!"£$%^&*()_+
    QWERTYUIOP{}~
    ASDFGHJKL:@
    ZXCVBNM<>?
    no sign of a pipe symbol anywhere (except on the key that echoes # and ~)
    @octatonic yeah right :)
    No ALT key?  Or ALT GR?
  • there is an alt key. what is alt gr?
  • King85King85 Frets: 631
    If you take the hard drive out of the old laptop you can copy the files over via dos.
  • FX_MunkeeFX_Munkee Frets: 2478
    UNSHIFTED
    SHIFTED
    ¬!"£$%^&*()_+
    QWERTYUIOP{}~
    ASDFGHJKL:@
    ZXCVBNM<>?
    Alt Gr should be to the right of the space bar (mirror of Alt)
    Can't see your backslash key in the output above? pipe should be shift+backslash
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
  • 57Deluxe57Deluxe Frets: 7344
    New Cigars Day - I just want the old ones back... Rio 6 and Tampa Bay Nuggets in particular...
    <Vintage BOSS Upgrades>
  • @FX_Munkee (at work now) the keyboard on my computer at work has an alt-gr key, where you said I'd find it. I don't think the keyboard on my R.Pi at home has one. The key marked as if it should echo \ (shift = |) is to the left of z/Z on my keyboard at work, and it does just that. The key with the same labelling on the keyboard at home is in the place where #/~ is on the keyboard at work (ie on the extreme rh end of the middle line), and it actually echoes as #/~. Its as if the (smaller) keyboard at home is missing a key. This one at work is a Dell keyboard, BTW. The one at home is a cheap chinese nondescript job.
    Sounds like it's a US layout keyboard, if you set it to that the keys should actually do what they say.
    Not very helpful link for you as it's Windows, but it makes the differences clear:-
  • I know this sounds stupid but to get round this I googled "piped" command and then pasted the "|" into the terminal.
    “Ken sent me.”
  • @FX_Munkee I not sure could live with that (ie the keys doing what they say they do) because I'd probably lose hash and tilde while obtaining pipe and backslash. Pipe, tilde and hash are essential (backslash not so). I think I'd better get another keyboard.
    Pipe - because it, er, pipes in shell script and it means OR in C
    hash - because it is the comment delimiter in shell script
    tilde - because it is the bit inverter in C
    whereas backslash is only used (perversely) by Windoze as a filestore directory separator
    why TF can't people give you the characters you need on a keyboard??
    @Phil_aka_Pip TBH I think getting a normal UK layout keyboard is probably your best answer.
    I suspect you are right
  • @Phil_aka_Pip I've got a few spares I can let you have, just paste them in and let me know when you run out and need some more. Here are ten for starters ;)
