extend a jack without swapping the cable
darcymdarcym Frets: 1297
I'm doing some minor changes to my rack, and swapping out a pedal, the rack is really well cabled, professional job, pancake jacks just perfect, until I swap this pedal out, which has the input/output right next to each other so the pancakes won't allow both to plug in at the same time. I don't want to swap this cable out, nor do I want to take the jack off as chances are %50 that I'll either swap this pedal back or swap it to something different after some real world use.
Is it possible, is there a device or cable that can be made that will allow me to present one of the jacks as a standard "long" jack rather than pancake to test this pedal out ? sort like a headphone extension cable ?
  • ICBMICBM Frets: 72339
  • darcymdarcym Frets: 1297
    not so much worried about the cost, it's something that would be handy to have around anyway, more worried about the quality and will it work and will it impact anything ?
    This looks a great solution if you think it's something of "ok" quality
  • robinbowesrobinbowes Frets: 3042
    edited April 2019
    It would probably be OK for light use.
    @ICBM is right about the price - Neutrik connectors alone would cost > £10.
    This one is better quality:
    https://www.amazon.co.uk/Van-Damme-SPEAKER-Extension-Conductor/dp/B076PJQSMW
    Ignore that - it's a speaker extension. But the same with signal cable would be a similar price.
    R.
    The locking socket is excellent, the plug on the other end a bit less so - I'd prefer to see a NP2X - but still perfectly adequate for this job.
    At that price I'd probably buy two if this is something you may need again.
  • revsorgrevsorg Frets: 880
    Or a NP2X-B  ;)
    thanks guys, bought a few, looks like it maybe useful while trying out some of the rack changes.
  • prowlaprowla Frets: 4921
    That's the problem with pancake jacks - they take up a large area.
    I swapped to using EBS flats in my pedalboard.
  • GadgetGadget Frets: 895
    If I'm understanding you correctly, in that you want to simply extend the lead temporarily, why not just use a spare fx pedal (preferably true bypass) to connect two leads together? A bit cumbersome, but potentially zero cost just to try it out.
    I think, therefore.... I... ummmm........
