12 string Euro style JM build
Seeing all the pics  @HarrySeven posts on facebook makes my feed a lot more interesting than it used to be.
Last week there was an oddity kinda based on a Jazzmaster, but shape only, that instantly got saved as a screen saver.
i also found a 12 string neck I made about 10 years ago, slightly worse for wear but some lovely woods and still perfectly straight.
so it's going to be a 12 string bolt-on JM shape, but top bound with multiply binding and a sparkly blue finish top with off white back.  Probably non standard pickups, hardware and electronics for a vintage euro vibe
some pics will appear later
«13
    I'm in :)
    Sounds interesting, I like something a bit different from usual.....with your skills it will be awesome!....no pressure there then!
  • WezVWezV Frets: 16686
    this is the inspiration
    it wont end up anything like that... it certainly wont have a series of push buttons just above the strings for example, controls will be in a more regular location... and i may just go for 2 angled single coils.  still all to be decided
  • Sounds brilliant!
  • I like the cut of your jib!
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
    i got the body and neck pocket cut so have thrown a few parts on it
    i probably would have done something different with the headstock if i made the neck again now. it definitely looks a bit clumsy on this shape body, but i think that will suit the vibe by the time I am done.   At first i put the single coil covers on angled and realised i had walked right into surfcaster territory, obviously a slotted 12 string headstock adds to that a bit.
    Body is Dark Red Meranti, last guitar i made with it had a zingy acoustic warmth which i think will work well for this. the neck is some really nice black limba with a perfect macasser ebony fretboard... might need to add some inlays though
    That bridge was just close to hand, i am thinking it will have a hand made aluminium tailpiece  and bridge combo
    hmmm.   i bet the blue guitar above is a drum wrap finish.   maybe i should try that???
  • Just an FYI - the blue guitar is an Eko Ekomaster 400.
    Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • @WezV - One of these days, I think we should talk turkey re. a crazy custom build... :)
  • Is it bad form to call dibs already? Are there any guitars of yours I *haven't* dibs-ed at this point? :D
    I thought it was something like that. Definitely a vinyl wrap then
  • HarrySevenHarrySeven Frets: 8031
    edited November 2016
  • SporkySporky Frets: 28332
    Yes. Yes you should. It looks magnificent.
    Re the headstock; could you reshape just the end a little to make it asymmetrical? Or is that even more Surfcastery?
  • impmannimpmann Frets: 12667
    Blue sparkly 12 string Jazzmaster? Oh yes! Great idea.
    As an aside, those Schaller roller bridges are *BRILLIANT* on Shergolds, Wez... if you pop the original rattly bridge off, these fit very well, cover the old fixing holes and *TRANSFORM* the tone. I was going to do that to the one I sold you...
    Cheers for the heads up, I might give that a go.
    I was actually looking at the shergold bridge wondering if something like that would work for this project
  • I've spent the last few weeks looking at the gold version of this in Hanks window on Demark street. Sadly it wasn't set up at all when I played it, massive bow in the neck and no sound from the pickups.
    Definitely a plastic top and back, originally made by an accordion factory, hence the odd control plate and plastics.
    I'll be following this with great interest.
    yes, i know Brandonni guitars used to offer the accordion treatment for guitars as well as selling a lot of Eko stuff.  I am just looking into DIY solutions, but i know I can do both white pearl and sparkly blue with paint so we will see
  • Oh man. In before the awesome.
  • Following this one.
    How about a trem? Indeed how about a trem for the six higher strings only. Always fancied trying that.
    Following this one.
    That sounds ridiculous.
    I like it :)
