Advice request - endpin replacement on an acoustic
So having got a K&K Pure Mini acoustic pick up for my acoustic 12-string, I sent Levinson an email asking if the endpin is glued in or screwed in or just stuck in tight.
They sent me these in response, saying this is how they do it -
These suggest to me that I saw off the sticky out bit of the endpin, then drill through the rest of it.
I'm a bit wary of the potential for scratching the bejaysus out of the finish, but fair enough, if that's how one does it, that's how one does it. (Yes I can see there's masking tape around it, but it's not the most robust of defences in my experience.)
Do the experts here agree and if not, how would you do it?
If you must have sex with a frog, wear a condom. If you want the frog to have fun, rib it.
  • WezVWezV Frets: 16688
    Yeah, I had to do a glued in one this week it's pretty close to what I did.
    i cut further away from the body and drilled a 3mm hole down the centre before going for the bigger drill bit
  • Fair do's, I shall swallow hard and give it a go when I have some time.
    Gulp.
    (I was going to add I'll cross my fingers, but I'm not sure how I'd hold the blade properly if I did that.)
  • ICBMICBM Frets: 72382
    I don't think I've ever come across one that was glued in so strongly that I couldn't get it out with Mole Grips. You may as well try since if it breaks off you're going to end up drilling it out anyway.
  • It's not the endpin I'm worried about damaging...
    edited November 2016
    It's not the endpin I'm worried about damaging…
    It would be a good idea to protect the end of the guitar whatever you do.
    I probably should have said, if the endpin is glued I grip the head of it sideways with the Mole grips and rotate it to break the glue first, rather than trying to just pull it straight out.
  • Ah, right. Personally I'd have tried to wiggle it a bit, to see if that worked, but yes, protection is essential.
