TELL ME WHICH EXPRESSION PEDAL TO BUY!!!
EricTheWearyEricTheWeary Frets: 16297
PLEASE!!!
- this is experimental, I really can't say if it will be something I will get a lot of use out of so cheap as possible, long term sturdiness not a big issue. It will be off my pedal board, if that makes a difference.
- if it doesn't come with a cable then what do I need, is it just a guitar cable?
- this is for my tc X4 delay for a couple of trippy endings.
- I am assuming this will be a passive device that I can plonk on the floor somewhere convenient, plug into the X4 and go.Or is that not how it works?
- I have the X4 instructions on how to set up expression pedal parameters so that bit should be okay ( famous last words).
- I don't need it to work as a volume pedal. However, if it does then that might be a bonus if I get fed up of going booooiiinnnggg, boooooiiinnggg,booooiiinnnggg,booooiiinnnggg...
- from googling quite liking the Moog EP-3 but I honestly don't know if that's the right thing or not!
Ta
  • FazerFazer Frets: 467
    get the moog you mention, or the roland rv-5
    the rolands are always on ebay and its all ready to go with inbuilt cable
    ..... but do a quick websearch first to check its ok with the tc x4! it works 100% fine with all my 'normal' exp pedal inputs
  • EricTheWearyEricTheWeary Frets: 16297
    Cheers. TC don't seem to reccomend a pedal but in googling this I found someone who seemed to have used the Roland RV 5 ( wasn't 100% clear) and someone else who used the Moog EP-2, which seems to have been replaced with the EP -3 which seems to be a generally better built pedal. The EP-3 is relatively cheap on Thomann so I guess I could just send it back if it doesn't work.
  • GassageGassage Frets: 30928
    Eric- the VP Jr does a great job too
  • stickyfiddlestickyfiddle Frets: 27105
    +1 for the EB VP Jr. Great feel and bombproof
    EB VP Jr + insert cable ... Ps have same for sale pm if interested
    the VP Jr is on the pricey side for something experimental so unless you are feeling charitable...
    The Moog ep-3 is quite new and generally put of stock but even with p and p hugely cheaper from Thomann than UK dealers so I might pre order from them if nothing turns up cheap as chips on eBay.
  • If a Roland EV5 is compatible, I have one I'd sell
    If you're looking for a real budget deal - look at bastardising a dunlop wah ...
    I do have one that I never use. Would have to be a moronically simple process though for me to do it!
    PM me up if you like?
    Re the mod for wah to exp pedal - google it - fairly simple afaik
    will look, Ta.
  • For an expression pedal, I've had the best luck with an EV-5 over the years...shame it's so lightweight. I always use a EB VP Jr for volume duties.
