PLEASE!!!
- this is experimental, I really can't say if it will be something I will get a lot of use out of so cheap as possible, long term sturdiness not a big issue. It will be off my pedal board, if that makes a difference.
- if it doesn't come with a cable then what do I need, is it just a guitar cable?
- this is for my tc X4 delay for a couple of trippy endings.
- I am assuming this will be a passive device that I can plonk on the floor somewhere convenient, plug into the X4 and go.Or is that not how it works?
- I have the X4 instructions on how to set up expression pedal parameters so that bit should be okay ( famous last words).
- I don't need it to work as a volume pedal. However, if it does then that might be a bonus if I get fed up of going booooiiinnnggg, boooooiiinnggg,booooiiinnnggg,booooiiinnnggg...
- from googling quite liking the Moog EP-3 but I honestly don't know if that's the right thing or not!
Ta
the rolands are always on ebay and its all ready to go with inbuilt cable
..... but do a quick websearch first to check its ok with the tc x4! it works 100% fine with all my 'normal' exp pedal inputs
The Moog ep-3 is quite new and generally put of stock but even with p and p hugely cheaper from Thomann than UK dealers so I might pre order from them if nothing turns up cheap as chips on eBay.
